96 Blazer Heater Core
JOPA1
Does anyone know how to bypass the heater core so I don't have to replace at this time? I'm told it's OK to use the AC as heat source it this true?
May 15, 2007 at 2:43 AM
MIKE H R
  • 3,094 POSTS
where the two coolant lines go into the firewall, disconnect them and run from one to the other, don't know how much heat you are going to get from the a/c, what heats the car is the coolant going through the heater core
May 15, 2007 at 11:54 AM
