How do I change the headlight bulb?
61,000 MILES • 6 CYL • 2WD • AUTOMATIC
THOMAS2007
how do i change a low beam head lamp
Sep 26, 2010 at 6:16 AM
RAZERBACK
  • 15 POSTS
the headlights are under hood find it grab and turn pull out hi and low are all together in one don't touch new bulb with your fingers it blows as soon as you turn on no tools needed just pull out. Here is a video to help you step by step with instructions in the diagrams below to show you how on your car.
https://youtu.be/e-gDH1Ce_7E
Oct 15, 2010 at 2:50 AM
BASSFISH
How do I replace the passenger side headlight on a 2005 Chevy Trailblazer?
Jan 7, 2021 at 2:26 AM (Merged)
DENNYP
  • 1,824 POSTS
xTooltipElement Service Information 2005 Chevrolet TrailBlazer - 4WD | Envoy, Rainier, TrailBlazer, Ascender (VIN S/T) Service Manual | Body | Lighting Systems | Repair Instructions | Document ID: 742449 Headlamp Replacement (TrailBlazer) Removal Procedure Open and support the hood. Remove the grille. Refer to Grille Replacement . Pull up on the retaining tabs (1) in order to remove the headlamp assembly from the headlamp panel. Disconnect the headlamp leveling electrical connector from the motor/actuator if equipped. Disconnect the headlamp electrical connector (2) from the headlamp assembly. Remove the side marker socket (4) from the headlamp assembly. Remove the park/turn socket (3) from the headlamp assembly. Remove the headlamp assembly from the headlamp panel. Installation Procedure Position the headlamp assembly to the headlamp panel. Index and seat the tabs on the park/turn socket (3) to the headlamp assembly. Index and seat the tabs on the side marker socket (4) to the headlamp assembly. Connect the headlamp electrical connector (2). Connect the headlamp leveling electrical connector to the motor/actuator if equipped. Align and install the 4 locator pins on the back of the headlamp assembly into the retaining tab holes. Push down on the retaining tabs (1) in order to lock the headlamp assembly into the headlamp panel. Install the grille. Refer to Grille Replacement . Close the hood. © 2008 General Motors Corporation. All rights reserved.
https://images.2carpros.com/forum/automotive_pictures/102900_742007_1.jpg
REASON1
Electrical problem
2005 Chevy Trailblazer Four Wheel Drive Automatic
What's the trick to changing a burned out headlight?
Jan 7, 2021 at 2:27 AM (Merged)
MASTERTECHTIM
  • 4,750 POSTS
https://images.2carpros.com/forum/automotive_pictures/139033_no_13.jpg
ok lift up the #1 rods about one inch, this will unhook the headlamp assembly and you will be able to slide it forward to access the bulbs. be gentle, once you get it out you will see how easy it is. hope this helps
REASON1
[quote="Reason1"]Electrical problem
Thanks to Mastertechtim about changing bad headlight. I was told buy parts store guy that the whole grill had to come off. Thanks Again, Rudy
PHONE7441
i am trying to change the low beam headlight,and i have no idea how to access the thing. i have owned many different types of vehicles and i have never had this kind of dilema. thank you
WALT09
Hi-
I just did mine this afternoon after looking for an answer myself on this web site. I saw a diagram responding to one of the 2003 TB headlight replacement questions (there are several with the same question.)
The process wasn't too bad and didn't take that long.
The front grill comes off with a little encouragement: there are 4 clips along the top, 2 on each side in the middle of each headlight assembly, 2 on the bottom - 1 on each side near the headlight assemblies, and 1 in the middle behind the Chevy logo. Once the grill is off you have access to each headlight assembly.
I found a tab at the top on each side of the assembly that pulls up. It took some doing to pry the ones on the outside because they were hard to get to. Pulling both tabs up releases the assembly. I disconnected the headlight connector and also removed the turn signal light with its connector attached. I left the side light and connector attached with the assembly. I swung the assembly to the outside and removed the dust covers for each light (low bean 9006 on the outside and hi beam 9005 on the inside). I replaced both lights because I didn't want to go through this process again any time soon. I put the dust covers back on and did everything in reverse. I checked each headlight assembly after I replaced those lights and only put the decorative grill back on when I knew all the lights were working properly. The most difficult task was replacing the lights on the right/passenger side of the car. The ones on the left/driver side were much easier to both remove and install.
Good luck with your replacements.
LHOUSELOVER
https://www.2carpros.com/articles/how-to-replace-a-headlight-bulb
it is a lot easier and it took my husband and I about 10 minutes to change ours.
SCIVANICH
How do I Change the headlight bulb
  • 110,248 POSTS
Removal Procedure
Caution: Halogen bulbs contain gas under pressure. Handling a bulb improperly could cause it to shatter into flying glass fragments. To help avoid personal injury:
- Turn off the lamp switch and allow the bulb to cool before changing the bulb.
- Leave the lamp switch OFF until the bulb change is complete.
- Always wear eye protection when changing a halogen bulb.
- Handle the bulb only by its base. Avoid touching the glass.
- Keep dirt and moisture off the bulb.
- Properly dispose of the used bulb.
- Keep halogen bulbs out of the reach of children.
Notice: Avoid touching the bulb or letting the bulb come in contact with anything damp. Oil from your skin or moisture on the bulb can cause the bulb to explode when the bulb is turned on. If either comes in contact with the bulb, clean the bulb with alcohol or a suitable degreaser and wipe the bulb dry.
1. Open the hood.
2. Remove the access cover from the rear of the headlamp.
3. Rotate the bulb and socket counterclockwise in order to remove the bulb and socket from the housing.
4. Disconnect the electrical connector from the socket.
Important:
- Replace a high beam bulb with another high beam bulb. The high beam bulb has a black socket.
- Replace a low beam bulb with another low beam bulb. The low beam bulb has a gray tip and a grey socket.
1. Connect the electrical connector to the socket.
2. Position the bulb and socket to the headlamp.
3. Install the bulb and socket to the housing by rotating the bulb and socket clockwise, locking the retaining tabs to the housing.
4. Install the access cover to the rear of the headlamp assembly.
See picture below
GUITARROCKERISME
In addition to Jacobandnickolas, you will see a round, rubber cover on the back of the headlight assembly. That just pops off and then you can access the bulb.
M.LARSON
How do I replace the headlight bulb in the 2003 Chevy Trailbalzer?
JDL
  • 16,098 POSTS
https://images.2carpros.com/forum/automotive_pictures/170934_chevy_trailblazer_1.jpg
https://images.2carpros.com/forum/automotive_pictures/170934_trailblazer1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/170934_trailbazer_2_1.jpg
STEVENU
How do I access the headlight assembly so as to replace the bulb
BLUELIGHTNIN6
  • 16,542 POSTS
Make sure the headlight switch is in the "Off" position. Release the hood latch, and open the hood.
Remove the black radiator valance that runs across the front width of the engine compartment by removing the two screws with the Phillips screwdriver and the three pushpin plastic retainers.
Locate the four retaining clips to the grill under the valance, and firmly but gently push down on the clips with the flat-head screwdriver to release them.
Unfasten the retaining grill clip located at each headlight assembly, and pull up gently on the grill assembly to release it from the other lower clips. It should come right off.
Locate the retaining tabs of the headlight assembly at the top of each headlight assembly; these tabs are L-shaped bars that lock onto two rivet heads and hold the headlight assembly in place from behind. Lift the left and right tabs of the respective headlight assembly as far as they will go. You may need to convince the tabs with the flat-head screwdriver.
Pull the headlight assembly forward, and pull off the black rubber cover.
Unplug the wire harness that goes into the respective lightbulb. High-beam bulbs are located on the inside of the assembly, and low-beam bulbs are on the outside of the assembly.
Turn the bulb retainer 1/4 turn counterclockwise to release it from the headlight assembly. Remove the old bulb,
Insert the new bulb, being careful not to touch the glass bulb of the new headlight. Turn the bulb retainer 1/4 turn clockwise to lock the bulb in place. Plug in the wire harness.
Test the headlight before putting everything back together.
Replace the black rubber cover, and put the headlight assembly back into the cavity. Secure it by locking the tabs into place.
Replace the grill, and snap the retaining clips back into place. Replace the valance and hardware, and close the hood.
NICK GOMEZ
2003 Chevy Trailblazer
how do you replace headlights?
  • 75,988 POSTS
HEADLAMP REPLACEMENT REMOVAL PROCEDURE 1.Open and support the hood. 2.Remove the grille.
https://images.2carpros.com/forum/automotive_pictures/12900_hl_1.gif
3.Pull up on the retaining tabs (1) in order to remove the headlamp assembly from the headlamp panel. 4.Disconnect the headlamp leveling electrical connector from the motor/actuator if equipped. 5.Disconnect the headlamp electrical connector (2) from the headlamp assembly. 6.Remove the side marker socket (4) from the headlamp assembly. 7.Remove the park/turn socket (3) from the headlamp assembly. 8.Remove the headlamp assembly from the headlamp panel. INSTALLATION PROCEDURE 1.Position the headlamp assembly to the headlamp panel. 2.Index and seat the tabs on the park/turn socket (3) to the headlamp assembly. 3.Index and seat the tabs on the side marker socket (4) to the headlamp assembly. 4.Connect the headlamp electrical connector (2). 5.Connect the headlamp leveling electrical connector to the motor/actuator if equipped. 6.Align and install the 4 locator pins on the back of the headlamp assembly into the retaining tab holes. 7.Push down on the retaining tabs (1) in order to lock the headlamp assembly into the headlamp panel. 8.Install the grille. 9.Close the hood.
Jan 7, 2021 at 2:28 AM (Merged)
JERRYMONROE
Electrical problem
2003 Chevy Trailblazer 6 cyl Two Wheel Drive Automatic
How do you change the head light on a 2003
Chevy trail Blazer?
BLUELIGHTNIN6
  • 16,542 POSTS
Remove the grill by pulling the tabs forward across the top of the grill. There are several tabs that need removed. The grill covers both left and right headlamps, with two tabs on left and right side. You can't tip the headlights forward without removing. Once grill is removed pull up on the two retaining tabs on the headlamp. One tab is hidden by the fender. Lamp will fall forward, you may need to lift it up slightly. May help to remove turn signal lamp to get more slack to work with. Remover rubber cover on back of bulb, twist out bulb, disconnect, and replace.
Align the grill, snap the grill back in across the top, don't forget to snap the tabs into both headlamps.
JMS1953
Electrical problem
2003 Chevy Trailblazer 6 cyl All Wheel Drive Automatic
I need detailed instructions for changing the drivers side low-beam headlight for a 2003 Chevy Trailblazer.
  • 110,248 POSTS
The head light bulb is replaced from under the hood of the vehicle. Open the hood and look behind the light assembly. There you will see where the sockets are screwed into the assembly. Turn the socket 1/3 turn counter clockwise to remove bulb. Once open remove the old bulb and replace it with the new one. NOTE: Try to avoid touching the glass of the new bulb. The oils from your skin will cause it to go bad sooner. Let me know if you have any questions. Here is a picture of the bulb itself:
https://images.2carpros.com/forum/automotive_pictures/249084_light_2.jpg
JAMALCOM
how to replace low beam headlight on passenger side
nothing in manual
MASTERTECHTIM
  • 4,750 POSTS
pull up the #1 rods and this will release the light assembly and it will pull straight out
https://images.2carpros.com/forum/automotive_pictures/139033_no_19.jpg
KEVIN_LOWE_419
how do i get access to headlight to change bulb
HMAC300
  • 48,601 POSTS
you should be able to get behind the headlight and turn thebulb out but unhook the connector first. You may have to remove a panel on top to reach it , but that should have either screws or push pins holding it or both.
BOB18328
How do you change the low beam bulb on the passenger side?
