alternator removal
2007 CHEVROLET TRAILBLAZER
36,000 MILES • V8 • 4WD • AUTOMATIC
CABO
bearing going out on alternator, how to remove and install replacement
Dec 10, 2009 at 11:32 PM
BRIAN 1
  • 1,030 POSTS
Hello
Here is a guide to help walk you through the steps with instructions in the diagrams below to show you how on your car.
https://www.2carpros.com/articles/how-to-replace-an-alternator
Dec 11, 2009 at 2:32 AM
JESS86
My car has been dying over night , I have changed the alternator and the battery it was doing good for about a day or two then the problem started again. The service engine light does not come on. Any Ideas what it could be???????? When I got the new battery checked it before I put it one and it was at 99% when they checked It again after it was put on it when down to 68% and said it needed charge.
Nov 23, 2019 at 10:25 AM (Merged)
Electrical pressure decreasing sounds like you need to have the alternator load tested whether its outputting the correct voltages-start here
TCTOWN76180
my son had a battery replaced last week in his trailblazer and a guy told him his alternator was putting out too many amps. He drove 450 miles on the new battery with the ac, gps and dvd player going without any problems. Today, before going on another trip, he had the alternator checked again and this guy told him it wasn't putting out enough amps. How many amps should he be putting out.
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:10b61fe60f="tctown76180"]Electrical problem
2004 Chevy Trailblazer 6 cyl Four Wheel Drive Automatic 79000 miles
my son had a battery replaced last week in his trailblazer and a guy told him his alternator was putting out too many amps. He drove 450 miles on the new battery with the ac, gps and dvd player going without any problems. Today, before going on another trip, he had the alternator checked again and this guy told him it wasn't putting out enough amps. How many amps should he be putting out.[/quote:10b61fe60f]
The alternator using a Digital Volt Meter should be putting out between 13.5 and 14.5 .
If any doubts go by your local AutoZone and have them check it for you.
BK_IOOF
diagrams for changing out a alternator bolt locations
MMPRINCE4000
  • 8,548 POSTS
https://images.2carpros.com/forum/automotive_pictures/108325_alttrailblazer_1.jpg
GREG KING
how to replace
  • 110,240 POSTS
Greg:
This is a straight forward repair. First, disconnect the battery. Rmove the serp belt and wiring from the alternator. After that, remove the mounting bolts that hold the alt to the mounting brackets and the alt will come off. Reverse the order to replace it.
If you run into trouble, let me know.
HMAC300
  • 48,601 POSTS
I've been asked to help out, check battery for condition including load test. most places do for free. then replace belt and tensioner as 60k is recommended the tensioner loses tension, belt slips and causes everything to draw down. make sure the battery terminals are clean as well. finally clean throttle plate on both sides and iac hole with choke cleaner. the sensor you are talking about kinda behind the alternator is the coolant temp sensor.
GRIM216618
The battery is new. I replaced it less than a month ago. How do I clean the throttle plate and iac hole?
HMAC300
  • 48,601 POSTS
use choke cleaner and clean both sides of plat e an iac hole there is a article on our repair site here. YOu don't need to remove it to clean it like the article shows.
https://www.2carpros.com/articles/car-battery-dead-overnight
