2006 Chevy Trailblazer Won't Idle correctly and code came b
98,000 MILES • 6 CYL • 4WD • AUTOMATIC
HARDTRAILZ400
I have only had my 2006 TrailBlazer 4.2L 4x4 w 95,000 miles for 3000 miles or so and have nothing but problems. I started with a check engine light and poor idle and stalling at idle. I had the codes ran and it came back as 0014, 0017, and 0300.
I got and installed new AC Delco Iradium plugs, a new crankshaft position sensor, and a new camshaft position sensor. I also cleaned the thottle body. I also left the battery unhooked for 4 or 5 hours.
This was about 1500 miles ago and it at first did not fix the problems, but after a few starts and miles, the light went out and all problems were gone. It idled fine, never stalled, had no lights on.
Then Friday the engine light returned and the truck will not idle properly. It surges at idle and will occasionally stall out. It is worse when the truck is cold. It does not make a difference if the HVAC is off or on. The engine will miss so bad the truck will shake at idle and has a loss in power. The engine light will flash and then the truck will run a bit better, but the light never goes away, it just stays on and the horrible idle is still there at the next light.
Feb 24, 2009 at 1:36 AM
BRIAN 1
  • 1,030 POSTS
follow this info,Some customers may complaint of an engine belt noise, rough idle, and/or SES light with DTC P0014 and/or P0017. If a rough idle is experienced, a P0106 may be stored as well.
https://images.2carpros.com/forum/automotive_pictures/147643_solenoid_1.jpg
Screen for Advance Pressure to Camshaft Actuator (2) Screen for Pressurized Oil from Oil Pump (3) Screen for Retard Pressure to Camshaft Actuator If any of these screens are missing, replace the camshaft actuator solenoid, change the engine oil and filter, and re-evaluate the concern post back with any other questions.
Feb 24, 2009 at 11:04 AM
