2006 Chevy Trailblazer WHINNING NOISE WHEN I AM DRIVING
JACOLEMA
Noises problem
2006 Chevy Trailblazer 6 cyl Automatic
here whinning noise when driving like when i step on the gas
Sep 16, 2010 at 2:39 PM
MADMIKE1735
  • 951 POSTS
sounds like there is air in the powersteering pump. check fluid level... also check for bubbles in the power steering fluid. let us know the results.
Sep 20, 2010 at 3:45 PM
SOLDIERMEDIC79
  • 9 POSTS
I had the same problem, and it was the idler pulley. IF it happens when you hit the gas, that's it. Check your belt diagram and listen for a noise in the right side of the engine block. Have someone rev the engine while you listen.
Oct 27, 2010 at 6:56 AM
MADMIKE1735
  • 951 POSTS
an idler pulley is also another possibility.... remember, us techs are trying to diagnose your problems over the internet... so its much harder to say for sure without adequate information.
Oct 29, 2010 at 3:42 PM
