2006 Chevy Trailblazer Problem with brake lights
MNBUENAGIRL
Electrical problem
2006 Chevy Trailblazer All Wheel Drive 51446 miles
I am having a problem with my brake lights. Both have went out even after we have changed the bulbs. I looked in the manuel to make sure that we had the correct bulbs and they still are not working. However the turn signal bulbs and the reverse bulbs work perfectly. Please provide some suggestions on how to fix. Thanks!
Jan 12, 2010 at 4:50 AM
DOCFIXIT
  • 18,828 POSTS
Most likely the turn signal switch is faulty a common repair
Jan 12, 2010 at 5:04 AM
MNBUENAGIRL
So, you think that the turn signal switch is faulty even though the turn signal lights are working and the brake lights are out?
Jan 12, 2010 at 6:53 AM
DOCFIXIT
  • 18,828 POSTS
yes brake light circuit goes through turn signal switch. Have you looked at brake switch on top of pedal? When pedal depressed switch closes and completes circuit.
Jan 12, 2010 at 8:01 AM
