2006 Chevy Trailblazer P2101
38,000 MILES • 6 CYL • 4WD • AUTOMATIC
BROWNJOYJER
P2101 is the error code I got and all I can find out is that it's the Throttle Air Motor position too low. Can you help.
Sep 22, 2008 at 8:02 AM
BRIAN 1
  • 1,030 POSTS
The Throttle Actuator Control (TAC) / throttle body type trouble codes, may be caused by a loose wiring crimp at the throttle body connector, or a broken throttle body circuit.Inspect all related throttle body terminals for a loose wiring crimp. The loose crimp may be difficult to find, and the poor connection will be between the terminal and the copper strands of the wire. Wiggle test the individual throttle body circuits to see if the concern can be duplicated.
Inspect the related circuits for broken wires inside the insulation. The outer wire insulation may look fine, but the internal copper strands may be partially broken. Breaks in the wires usually occur within 1 to 4 inches of the throttle body connector. Wiggle testing may also induce a trouble code to set. If a terminal crimp or a broken wire has been found, repair or replace only the circuits involved. There is a throttle body pigtail connector available
Sep 23, 2008 at 8:46 AM
