2006 Chevy Trailblazer Non Working Brake Lights
2006 CHEVROLET TRAILBLAZER
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
NOMECH63
Brake light on passenger side does not work. I have replaced the bulb and checked fuses. What elese can I do?
Oct 23, 2009 at 3:39 PM
  • 110,240 POSTS
I need you to check to see if the socket is getting power. Often times the circuit board will go bad or the socket itself. I believe you have individual sockets on this vehicle. Let me know. NOTE: Also check the wiring to the socket because you can loose power before the socket.
Feb 27, 2021 at 4:33 AM
