2006 Chevy Trailblazer Driver side window
65,000 MILES • 6 CYL • 4WD • AUTOMATIC
BOOCHIE
I have a 2006 trailblazer. The driver side window works some times and some times not. when it don't work the inside lights take longer to cut off. What can cause that?
Aug 5, 2010 at 12:33 PM
  • 110,246 POSTS
I don't know if the light is related unless there is a problem with the body control module. As far as the window, when it doesn't work, have you checked to see if there is power to the motor?
Sep 1, 2010 at 2:32 AM
