2006 Chevy Trailblazer Battery and Healights
97,000 MILES • 6 CYL • 2WD • AUTOMATIC
PRETTYLADYLISA
I recently had the Ignition switch changed on my car and now the battery light stays on when the car is turned off. And if I leave it off for too long it will kill the battery so I am having to undo the battery cable everytime I am going to leave the car off for more than an hour or so.. I tested the battery and the alternator neither are bad .. Now after doing this for a few weeks my low beam head lights don't want to work and they are not burnt out I had them checked. I don't know if it is because of the battery problem or because of the ignition switch being installed improperly.
Nov 12, 2009 at 6:57 AM
HMAC300
  • 48,601 POSTS
take it back to where it was repaired . They either screwed something up doing the job or it's the wrong switch. You have a serious drain on your battery.
Nov 18, 2009 at 10:27 AM
