2006 Chevy Trailblazer Are spark plugs the problem?
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
DSTILES99
I have an 06 Trailblazer and about 2 months ago the mpg dropped from 20 to 17.5. I checked the tire pressures, changed the air filter, and used a can of injector cleaner at the next fill-up. No changes, after those and decided to change the spark plugs.
I used Bosch +4 Platinum to replace the OEM plugs and now I have a check engine light indicating an O2 sensor problem. The car runs fine. Would these plugs cause the O2 sensor to fail or is the sensor bad?
Mar 18, 2010 at 7:24 AM
CARADIODOC
  • 34,407 POSTS
The sure way to check the oxygen sensors is to have your machanic connect a hand-held computer, called a scanner, to watch what the O2 sensors are reporting. They should switch from rich to lean to rich a few times per second. If one of them is not responding properly, it will affect fuel metering and emissions.
Based on readings detected by the O2 sensors, the Engine Computer can adjust fuel delivery plus or minus around 10 percent beyond designed-in values.
caradiodoc
Mar 18, 2010 at 1:12 PM
