2005 Chevy Trailblazer waterpump replacement
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
GZEEMAN
How do you remove the large nut on the fan assembly that attaches to pump / Can't keep pulley from turning / Does this nut turn counterclockwise to loosen
Jul 18, 2009 at 7:22 AM
  • 55,583 POSTS
Hello, yes the threads are left hand, leave the drive belt on to help stop the pulley from turning. You might have to apply more pressure to the belt to help hold it. There is a special wrench that can be used to remove the fan clutch, but sometimes you can use a large crescent or equivalent. Please let me know how it goes. Thanks for using 2Carpros.com
Jul 20, 2009 at 5:51 AM
