2005 Chevy Trailblazer water pump and fan clutch
PENNY1323
Engine Mechanical problem
2005 Chevy Trailblazer All Wheel Drive Automatic 811500 miles
how do you know when to replace the water pump and fan clutch?
Mar 21, 2009 at 7:10 AM
DENNYP
  • 1,824 POSTS
The fan clutch will normally set a trouble code when it goes bad. Sometimes it might just get really loud. The water pump will get noisey,loose, or leak coolant. You can do a quick check by grabbing the fan blade and see if it moves up and down. If so, the water pump is bad.
Apr 7, 2009 at 3:25 AM
