2005 Chevy Trailblazer surging while stopped
2005 CHEVROLET TRAILBLAZER
DOOGLESMCSMOOGLES10
Engine Performance problem
2005 Chevy Trailblazer 6 cyl Four Wheel Drive Automatic
The vehicle seems to surge and starved for fuel while stopped at a red light or when in overdrive. It is worse when sitting at a stoplight.
Jan 11, 2010 at 7:41 PM
Check and test the following below:
Oygen Sensor
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Cap and Rotor
Note:If it doesn't apply,disregard.
Jan 11, 2010 at 8:01 PM
