2005 Chevy Trailblazer Rear Heater
40,000 MILES • 6 CYL • 4WD • AUTOMATIC
TECHMECH57
  • 22 POSTS
Hi, the rear heater vents just blow cold air. The vents for the front system blow hot air and the engine temp is to specs. You can control the rear cabin fan speed from the front or from the rear. The fan speed will adjust with the controls from either one but no matter what you do all you can get from the rear vents is cold air. Thank you for your time.
Dec 22, 2008 at 5:56 AM
IMPALASS
  • 3,112 POSTS
Hello –
Are you sure the level of antifreeze is correct in the vehicle?
Next, from what you are saying it appears that the rear heater core may be plugged….once the vehicle is at operating temperature I would feel the inlet and outlet hose to see if they are both hot….if one is and one isn’t then the core is plugged.
Do you know how to get to it to check?
Dec 29, 2008 at 5:11 PM
TECHMECH57
  • 22 POSTS
They purchased this suv used with around 15,000 miles on it. From what I understand the rear heater has never worked for them. The check engine light started coming on once in awhile so I took a look at it and it was a code that said the engine wasnt warming up fast enough. It turned out to be the thermostat so I change it and topped off the anti-freeze then. So I know the anti-freeze level is good. They didnt tell me untill later when it started to get cold again about the rear heater problem. I havent had much to do with rear heaters on newer vehicles so was thinking maybe there is some controller not working right. I will check the heater lines when I get a chance to look at it again. But I wont think the heater core would be plugged with such low miles unless something got into the cooling system. Thanks for the info and your time.
Dec 30, 2008 at 5:25 AM
IMPALASS
  • 3,112 POSTS
Hello - First, Thank you for the update. By your reply it appears you didn't get the answer you were looking for. I apologize for that. One of our main tasks is to make sure we assist the customer so that they don't waste money being told something or purchasing something they didn't need. Depending on the coolant being used, like in your vehicle, some of the coolants are clogging up heater cores and radiators.....even with extremely low mileage. This is to the point the manufactures are putting TSBs out on them. That is why I suggested to first feel the hoses to see if there was a difference. Many times customers open a panel, look at something and it isn't anything like what they or we thought or the manual says. This is why before we suggested going out and purchasing something or doing this or that which may waste your time, I suggest to open up the area and get a good visual on it to actually see what is going on. If I suggest that you purchase something or that a controller is bad before you have even looked at it.....I would be doing you a disservice and I am here to save you money, not cost you money. I have located a TSB and attached for your review discussing the premature failure of the heater cores, radiators, and water pumps. As you see the TSB is dated Feb 2005. Depending on when your vehicle was made it may have just sat for some time even before the 15K was put on it. All that time....the problem may have been started and already in work. Also, I have attached a TSB discussing poor heat and the need to install an Auxiliary Heater Pump. Now you could do this but if the heater core is plugged then the auxiliary pump still will not make a difference and you have wasted your money. However, if you find both hoses are the same temp, no problems around the area, then I would do the auxiliary pump. My suggestion: First open the area and get a good visual on it. Check the hoses for both being hot or at least the same temp. Ensure there is no other problems in that area. If all is well, them my advice is the auxiliary pump. I hope this helps you out better and you have a better understanding of the direction I was going. Again, I apologize for appearing to not provide the info you requested. If you have any more questions, please feel free to get back with me...... Have a safe New Year. The TSBs Cooling System - Aluminum Radiator/Heater Core Info. Notes Information on Aluminum Heater Core and/or Radiator Replacement # 05-06-02-001 - (Feb 24, 2005) Models: 2005 and Prior Passenger Cars and Light Duty Trucks 2005 and Prior Saturn Vehicles This bulletin is being revised to add model years and enhance the content. Please discard Corporate Bulletin Number 73-62-13A (Section 06 - Engine Cooling). Important: 2004-05 Chevrolet Aveo (Pontiac Wave, Canada Only) does not use DEX-COOL(R) Refer to the flushing procedure explained later in this bulletin. The following information should be utilized when servicing aluminum heater core and/or radiators on repeat visits. A replacement may be necessary because erosion, corrosion, or insufficient inhibitor levels may cause damage to the heater core, radiator or water pump. A coolant check should be preformed whenever a heater core, radiator, or water pump is replaced. The following procedures/inspections should be done to verify proper coolant effectiveness. Caution: To avoid being burned, do not remove the radiator cap or surge tank cap while the engine is hot. The cooling system will release scalding fluid and steam under pressure if the radiator cap or surge tank cap is removed while the engine and radiator are still hot. Important: If the vehicle's coolant is low, drained out, or the customer has repeatedly added coolant or water to the system, then the system should be completely flushed using the procedure explained later in this bulletin. Technician Diagnosis ^ Verify coolant concentration. A 50% coolant/water solution ensures proper freeze and corrosion protection. Inhibitor levels cannot be easily measured in the field, but can be indirectly done by the measurement of coolant concentration. This must be done by using a Refractometer J 23688 (Fahrenheit scale) or J 26568 (centigrade scale), or equivalent, coolant tester. The Refractometer uses a minimal amount of coolant that can be taken from the coolant recovery reservoir, radiator or the engine block. Inexpensive gravity float testers (floating balls) will not completely analyze the coolant concentration fully and should not be used. The concentration levels should be between 50% and 65% coolant concentrate. This mixture will have a freeze point protection of -34 degrees Fahrenheit (-37 degrees Celsius). If the concentration is below 50%, the cooling system must be flushed. ^ Inspect the coolant flow restrictor if the vehicle is equipped with one. Refer to Service Information (SI) and/or the appropriate Service Manual for component location and condition for operation. ^ Verify that no electrolysis is present in the cooling system. This electrolysis test can be performed before or after the system has been repaired. Use a digital voltmeter set to 12 volts. Attach one test lead to the negative battery post and insert the other test lead into the radiator coolant, making sure the lead does not touch the filler neck or core. Any voltage reading over 0.3 volts indicates that stray current is finding its way into the coolant. Electrolysis is often an intermittent condition that occurs when a device or accessory that is mounted to the radiator is energized. This type of current could be caused from a poorly grounded cooling fan or some other accessory and can be verified by watching the volt meter and turning on and off various accessories or engage the starter motor. Before using one of the following flush procedures, the coolant recovery reservoir must be removed, drained, cleaned and reinstalled before refilling the system. Notice: ^ Using coolant other than DEX-COOL(R) may cause premature engine, heater core or radiator corrosion. In addition, the engine coolant may require changing sooner, at 30,000 miles (50,000 km) or 24 months, whichever occurs first. Any repairs would not be covered by your warranty. Always use DEX-COOL(R) (silicate free) coolant in your vehicle. ^ If you use an improper coolant mixture, your engine could overheat and be badly damaged. The repair cost would not be covered by your warranty. Too much water in the mixture can freeze and crack the engine, radiator, heater core and other parts. Flushing Procedures using DEX-COOL(R) Important: The following procedure recommends refilling the system with DEX-COOL(R) P/N 12346290 (in Canada, use P/N 10953464), GM specification 6277M. This coolant is orange in color and has a service interval of 5 years or 240,000 km (150,000 mi). However, when used on vehicles built prior to the introduction of DEX-COOL(R), maintenance intervals will remain the same as specified in the Owner's Manual. ^ If available, use the approved cooling system flush and fill machine (available through the GM Dealer Equipment Program) following the manufacturer's operating instructions. ^ If approved cooling system flush and fill machine is not available, drain the coolant and dispose of properly following the draining procedures in the appropriate Service Manual. Refill the system using clear, drinkable water and run the vehicle until the thermostat opens. Repeat and run the vehicle three (3) times to totally remove the old coolant or until the drained coolant is almost clear. Once the system is completely flushed, refill the cooling system to a 50%-60% concentration with DEX-COOL(R), P/N 12346290 (in Canada, use P/N 10953464), GM specification 6277M, following the refill procedures in the appropriate Service Manual. If a Service Manual is not available, fill half the capacity of the system with 100% DEX-COOL(R), P/N 12346290 (in Canada, use P/N 10953464), GM specification 6277M. Then slowly add clear, drinkable water (preferably distilled) to the system until the level of the coolant mixture has reached the base of the radiator neck. Wait two (2) minutes and reverify the coolant level. If necessary, add clean water to restore the coolant to the appropriate level. Once the system is refilled, reverify the coolant concentration using a Refractometer J 23688 (Fahrenheit scale) or J 26568 (centigrade scale) coolant tester, or equivalent. The concentration levels should be between 50% and 65%. Flushing Procedure using Conventional Silicated (Green Colored) Coolent Important: 2004-2005 Chevrolet Aveo (Pontiac Wave, Canada Only) does not use DEX-COOL(R). The Aveo and Wave are filled with conventional, silicated engine coolant that is blue in color. Silicated coolants are typically green in color and are required to be drained, flushed and refilled every 30,000 miles (48,000 km). The Aveo and Wave are to be serviced with conventional, silicated coolant. Use P/N 12378560 (1 gal) (in Canada, use P/N 993089 (4L). Refer to the Owner's Manual or Service Information (SI) for further information on OEM coolant. Important: Do not mix the OEM orange colored DEX-COOL(R) coolant with green colored coolant when adding coolant to the system or when servicing the vehicle's cooling system. Mixing the orange and green colored coolants will produce a brown coolant which may be a customer dissatisfier and will not extend the service interval to that of DEX-COOL(R). Conventional silicated coolants offered by GM Service and Parts Operations are green in color. ^ If available, use the approved cooling system flush and fill machine (available through the GM Dealer Equipment Program) following the manufacturer's operating instructions. ^ If approved cooling systems flush and fill machine is not available, drain coolant and dispose of properly following the draining procedures in appropriate Service Manual. Refill the system using clear, drinkable water and run vehicle until thermostat opens. Repeat and run vehicle three (3) times to totally remove old coolant or until drained coolant is almost clear. Once the system is completely flushed, refill the cooling system to a 50%-60% concentration with a good quality ethylene glycol base engine coolant, GM P/N 12378560, 1 gal (in Canada, use P/N 993089 4L), conforming to GM specification 1825M, or recycled coolant conforming to GM specification 1825M, following the refill procedures in the appropriate Service Manual. If a Service Manual is not available, fill half the capacity of the system with 100% good quality ethylene glycol base (green colored) engine coolant, GM P/N 12378560 1 gal., (in Canada, use P/N 993089 1L) conforming to GM specification 1825M. Then slowly add clear, drinkable water (preferably distilled) to system until the level of the coolant mixture has reached the base of the radiator neck. Wait two (2) minutes and recheck coolant level. If necessary, add clean water to restore coolant to the appropriate level. ^ Once the system is refilled, recheck the coolant concentration using a Refractometer J 23688 (Fahrenheit scale) or J 26568 (centigrade scale) coolant tester, or equivalent. Concentration levels should be between 50% and 65%.
https://images.2carpros.com/forum/automotive_pictures/248015_1_135.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_2_87.jpg
NEXT TSB A/C - Poor Rear Heater Performance Notes Bulletin No.: 05-01-37-002A Date: November 01, 2005 TECHNICAL Subject: Poor Rear Heat Performance (Install Auxiliary Heater Pump) Models: 2003-2005 Chevrolet TrailBlazer EXT 2003-2005 GMC Envoy XL Supercede: This bulletin is being revised to update the correction information. Please discard Corporate Bulletin Number 05-01-37-002 (Section 01 - HVAC). Important: Implementation of this Service Bulletin by "GM of Canada" dealers requires prior District Service Manager approval. Condition Some customers may comment on poor 2nd and/or 3rd row seating heater performance when the vehicle is at idle. Cause This condition may be due to lack of coolant circulation to the rear heater core. Correction Install auxiliary heater pump package, P/N 89024885 (L6 Engine RPO LL8) or P/N 89024886 (V8 Engine RPO LM4 or LH6). This pump will improve coolant flow to the rear heater core. Use the procedure listed below. 1. Recover the A/C refrigerant. 2. Drain the cooling system. 3. Disconnect the negative battery cable. 4. Remove the fender rear upper brace. 5. Remove the air cleaner cover. 6. Remove the air cleaner filter element and air outlet duct. 7. Remove the air inlet duct from the lower air cleaner housing/washer solvent tank assembly. 8. Disconnect the washer solvent tank electrical and remove wiring harness from the retaining clips. 9. Disconnect the washer pump hoses and plug the pump outlet ports to prevent loss of washer solvent. 10. Remove the two air cleaner housing/washer tank assembly retaining nuts from the mounting studs. 11. Lift the lower air cleaner housing/washer tank assembly off of the studs and remove the assembly. 12. On the A/C accumulator, disconnect the electrical connector from the low pressure switch. 13. Remove the compressor suction hose assembly from the accumulator. 14. Remove the nut retaining the accumulator to the evaporator. 15. Remove the coolant hoses from the coolant recovery reservoir. 16. Remove the nut and bolt securing the coolant recovery reservoir. 17. Remove the coolant recovery reservoir with the accumulator attached. 18. Remove the evaporator tube nut at the evaporator. 19. Remove the evaporator tube from the evaporator 20. Using the J 43181, disconnect the heater hoses from the core. 20.1. Install the J 43181 to the heater core hose. 20.2. Close the tool around the heater core hose. 20.3. Firmly pull the tool into the quick connect end of the heater hose. 20.4. Firmly grasp the heater hose. Pull the heater hose forward in order to disengage the hose from the heater core. 21. Disconnect the coolant bypass valve hose from the auxiliary rear heater line. 22. Disconnect the coolant bypass valve hose from the engine. 23. Disconnect the electrical connector from the coolant bypass valve. This connector will no longer be used. Tape off with electrical tape. 24. Disconnect the vacuum hose from the coolant bypass valve. 25. Remove the nut retaining the coolant bypass valve to the cowl and remove the coolant bypass valve with hoses attached. 26. Remove the heater hose quick connect retainers from the heater core pipes. 27. Remove the four nuts and the HVAC plate from the dash panel.
https://images.2carpros.com/forum/automotive_pictures/248015_3_61.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_4_38.jpg
28. Attach the new auxiliary heater pump to the new bracket using the supplied retainers as shown. Note the position of the pump on the bracket.
https://images.2carpros.com/forum/automotive_pictures/248015_5_25.jpg
29. Install the auxiliary heater pump and bracket onto the dash panel studs. 30. Reinstall the HVAC plate and nuts.
https://images.2carpros.com/forum/automotive_pictures/248015_6_14.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_7_15.jpg
31. On the coolant bypass valve, remove the hose (1) that went from the valve to the engine and discard.
https://images.2carpros.com/forum/automotive_pictures/248015_8_7.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_9_6.jpg
32. Install the new hose (1), # 1005 (L6 engine) or# 1006 (V8 engine) onto the coolant bypass valve at the location the above hose was removed. The other end of this hose will be installed on the auxiliary heater pump outlet port.
https://images.2carpros.com/forum/automotive_pictures/248015_10_5.jpg
33. Install the new hose, # 1003 (L6 engine) or # 1004 (V8 engine) onto the auxiliary heater pump inlet port. Connect the other quick connect end to the engine.
https://images.2carpros.com/forum/automotive_pictures/248015_11_4.jpg
34. Install the coolant bypass valve to its original location and secure with a nut. 35. Connect the other end of the new hose from step 29 to the outlet port of the auxiliary heater pump. 36. Connect the vacuum hose to the coolant bypass valve. 37. Connect the coolant bypass valve hose to the auxiliary rear heater line. 38. Install the heater hose quick connect retainers to the heater core pipes. 39. Connect the remaining two hoses to the heater core. 40. Install the new auxiliary heater pump wiring harness to the vehicle.
https://images.2carpros.com/forum/automotive_pictures/248015_12_4.jpg
40.1. Install the ring terminal (black wire) to ground G103 (1), located on the right side inner tender. 40.2. Route the pump wiring harness along the existing right side forward lamp harness.
https://images.2carpros.com/forum/automotive_pictures/248015_13_2.jpg
40.3. Connect the electrical connectors to the coolant bypass valve (1) and auxiliary heater pump (2).
https://images.2carpros.com/forum/automotive_pictures/248015_14_2.jpg
40.4. Position the relays onto the inner wheelhouse panel near the rear of the engine compartment.
https://images.2carpros.com/forum/automotive_pictures/248015_15_2.jpg
40.5. Route the other end of the harness along the rear of the engine compartment to the left side and secure to the cross bar and dash panel with tie straps.
https://images.2carpros.com/forum/automotive_pictures/248015_16_1.jpg
40.6. Install the ring terminal (orange wire) to the underhood fuse block stud (1).
https://images.2carpros.com/forum/automotive_pictures/248015_17_1.jpg
40.7. Locate circuit no. 241 or 441 (ignition 3 brown wire) (PIN B11 or C11) in the existing underhood fuse block harness (1) of C2 (2) and splice bare wire to it using a splice clip. Wrap with electrical tape. 40.8. Locate connector C105 (3), located on the left side inner fender. Separate the connector halves. On the female side of the connector, remove the terminal from cavity F (gray/black wire) and tape back. 40.9. Install the terminal end on the pump wiring harness into cavity F of connector C105. 41. Install the evaporator tube and nut to the evaporator. Tighten Tighten the nut to 28 N.m (21 lb ft). 42. Install the coolant recovery reservoir with the accumulator attached. 43. Install the nut and bolt securing the coolant recovery reservoir. 44. Install the coolant hoses to the coolant recovery reservoir. 45. Install the nut retaining the accumulator to the evaporator. Tighten Tighten the nut to 28 N.m (21 lb ft). 46. Install the compressor suction hose assembly to the accumulator. Tighten Tighten the nut to 48 N.m (35 lb ft). 47. Connect the electrical connector to the A/C low pressure switch. 48. Install the lower air cleaner housing/washer solvent tank assembly onto the mounting studs. 49. Install the two air cleaner housing/washer tank assembly retaining nuts to the mounting studs. 50. Connect the washer pump hoses. 51. Connect the washer solvent tank electrical and install wiring harness to the retaining clips. 52. Install the air inlet duct to the lower air cleaner housing/washer solvent tank assembly. 53. Install the air cleaner filter element and air outlet duct. 54. Install the air cleaner cover. 55. Install the tender rear upper brace. 56. Connect the negative battery cable. 57. Recharge the refrigerant system. 58. Fill the cooling system. 59. Inspect the cooling system for leaks. 60. Leak test the refrigerant fittings using J 39400-A.
https://images.2carpros.com/forum/automotive_pictures/248015_18_1.jpg
Parts Information Warranty Information
https://images.2carpros.com/forum/automotive_pictures/248015_19_1.jpg
Dec 30, 2008 at 10:27 AM
IMPALASS
  • 3,112 POSTS
Hello –
I was reviewing previous posts and wanted to provide you with this info. Looks like you may have some recalls on your vehicle. The dealer may fix these for free. Please contact the dealer service department, give them the VIN number of your car and have them check on these to see if they apply to you.
08089
06/13/2008
Campaign - Analog OnStar(R) Deactivation
04109
12/15/2004
Campaign - PCM Replacement
06102B
10/19/2007
Recall - Aftermarket Leather Seat Cover Kit
05002
03/03/2005
Recall - Windshield Replacement
NHTSA05V035000
02/02/2005
Recall 05V035000: Windshield Replacement
Dec 30, 2008 at 1:26 PM
TECHMECH57
  • 22 POSTS
First off let me thank you for all your time and info. Looks like you were right. I was finally able to get a look at it and you were right. One hose was warm and the other was cold. So I am assuming the core is plugged. They didnt have time to leave it so I will try and back flush it later. I would think just back flushing with water would do it or do you think I should have a radiator shop do it? It still might need that aux heater pump but want to try this first.
Jan 6, 2009 at 5:38 AM
IMPALASS
  • 3,112 POSTS
Hello –
You are more than welcome on the help/info……………………
To me…………and again………….this is just my thought………if it were me I would replace it. It looks like it runs about $77 at Auto Zone and I show two part numbers from Chevy…. a 15-63083 and 8902339 both for about $148 beans………
From what I see once you get the panels off it is easy access……..compared to the front core that you have to take the dash apart………….I may be wrong but that is what my manual shows……
Next, a back flush by you……….you could instantly see good flow……..a radiator shop…..would probably use a chemical……………but to me…..I just haven’t had really good luck on back flushing……………I replace………….the ports….or core holes are pretty small and you can actually take a infrared thermometer and go across a radiator and it will show hot and cool spots………….thus you will have flow but some areas are blocked…………..
It sat for a while…………had about 15K put on it…………your in-laws (I think you said) have had it for a year or more to get up to about 40K………….That is now about 4 years………to me the cost of replacement will be almost as much as the flush and you are sure to have a good clean clear one if replaced………………..so to me…………I would just replace………it may even be cheaper than the flush…………………..
What are your thoughts????
Oh, if you are still running the Dex-cool I would flush that out and go with the green Prestone. You can purchase a flush kit at AutoZone by Prestone, it has a T-Fitting you plug right into your heater hose……..hook the water hose to it, crank the engine and remove the radiator cap and away it goes………………..this flushes the engine also…………gets it all out………
Then you drain……and refill 50/50 with the green Prestone.
If it were me……………..I would do the complete flush………………drain………..replace the rear core………….fill/bleed and see how it does……….
I totally agree with you……………first get the heater going and then check on the aux pump….if may run you out of the back the way it is…………..
Let me know what you think……………….
Oh, did you have time to check on the recalls………….did any apply?
Thanks and have a great day.
Jan 6, 2009 at 8:21 AM
TECHMECH57
  • 22 POSTS
Thanks again for your time and ideas. I went with just the system flush and new anti-freeze and that seems to be working. Its been about a week and it still heats so I am hoping it will stay that way. thanks again. Dennis
Jan 29, 2009 at 8:00 AM
IMPALASS
  • 3,112 POSTS
Hello Dennis
I really appreciate you getting back with us and the update. This will help others that read the posts and maybe help them fix their problems.
Really glad to hear you are getting heat and is seems to be working.
Let us know if we can help in any other way………..
Stay warm!!
Jan 29, 2009 at 11:04 AM
