No Brake Lights
2005 CHEVROLET TRAILBLAZER
117,000 MILES • 6 CYL • 4WD • AUTOMATIC
JLW2010
I have a 2005 chevy trailblazer with no cruise control or brake lights. We have replaced the turn signal swith and sitll no cruise control or brake lights. We have checked all fuses both under rear seat and under hood and all are good. Any suggestions on what to do next????
Oct 1, 2010 at 10:59 AM
JDL
  • 16,098 POSTS
Do the high-mount brake lites work? Also, you can check for voltage at the stop lamp fuse circuit, use voltage tester, rear fuse block. You have to check with brake pedal applied. If no voltage, check for voltage at the brake lamp switch. Orange wire is hot all the time. When the brake pedal is applied, the white wire goes hot and carries voltage for brake lites.
Feb 27, 2021 at 12:33 PM
