2005 Chevy Trailblazer How do I change out a coil for Cylin
82,000 MILES • 4 CYL • 2WD • AUTOMATIC
EPWILKERSON938
Need help getting coil changed out on Cylinder #1 and putting in the 6 new plugs.
Apr 23, 2010 at 8:48 AM
RACEFAN966
  • 5,029 POSTS
Ok what you do is unplug the coil connector then unscrew the bolt that holds the coil in and then pull the coil up and out, the spark plug will be below the coil, so now remove and replace the spark plug and put it all back together. Now go to the next cylinder and repeat till all plugs are replaced.
Apr 24, 2010 at 2:29 AM
