2005 Chevy Trailblazer headlights
100,256 MILES • 6 CYL • 2WD • AUTOMATIC
ARTVISCONTI
when driving in the dark the headlights flicker when decelerating you will also see an additional load on the volt meter on the dash during the flickering. Where is the sensor that automaticly turns on the headlights?
Oct 22, 2009 at 7:48 AM
JDL
  • 16,098 POSTS
welcome to the forum, right now, I suspect the charging system is causing the issue. Alternator rpms effect alternator output to a certain point.
I believe there is light sensor, center top of dash.
Oct 22, 2009 at 2:53 PM
