2005 Chevy Trailblazer brake lights out
45,000 MILES • 6 CYL • 2WD • AUTOMATIC
ZEROTOLERENCE
My brake lights don't work. the third brake light works. checked fuses bulbs and looked at wires. is it the brake light switch? if so how do i change it.
Jan 13, 2008 at 12:10 AM
COORDINATOR15
[quote:24646c015a="zerotolerence"]Brakes problem
2005 Chevy Trailblazer 6 cyl Two Wheel Drive Automatic 45000 miles
My brake lights don't work. the third brake light works. checked fuses bulbs and looked at wires. is it the brake light switch? if so how do i change it.[/quote:24646c015a]
the 2004 trailblazer had a factory recall for this problem, all the brake lights (except the third high brake light) would burn out early. Call your Chevy deal and see if your vehicle is part of this recall. if so, they will perform a 15 minute procedure to change a some module and you will be back on the road...
it is free since it is a recall.
hope this solves your problem
Feb 27, 2021 at 4:34 AM
  • 110,248 POSTS
If the third, high mount stop lamp (CHMSL) is working, the brake light switch isn't the problem. If it was, the CHMSL wouldn't work as well.
If you look below, I attached the wiring schematic for the exterior lighting. I highlighted two fuses and pointed to where power is distributed. Note: After the switch, there is one fuse for the rear brake lights and a different fuse for the CHMSL. I suspect the fuse for the rear lights is bad.
The last pic is the clearest one related to the brake lights. Note I highlighted two fuses, one of which is circled in red. The circled one is for the CHMSL. It is good. The other one is where I suspect the problem to be. So, I need you to check that fuse.
When checking a fuse, it is important to not only inspect the fuse, but also to confirm there is power available to the fuse. Here is a link you may find helpful for doing this:
These fuses are located in the rear fuse box, below the left rear seat. Pic 5 below shows the fuse box, and I highlighted the fuse in question.
I hope this helps. Let me know if you have other questions.
See pics below. Note: I had to cut the wiring schematic pages in half to make them readable for you. I did overlap them so you can follow from one to the next.
Oct 8, 2021 at 1:13 PM
