2005 Chevy Trailblazer Blowing heat
2005 CHEVROLET TRAILBLAZER
LHOFFMAN77
Air Conditioning problem
2005 Chevy Trailblazer 6 cyl All Wheel Drive Automatic
The AC is blowing hot air when turned on instead of cold. I have checked the fluid levels & fuse, both ok. It has been woking fine, then today not so good.
Jul 4, 2010 at 3:12 PM
Check the high and low pressures using a manifold gauges could be no freon in it-if okay check the air blend door if its stuck in the heat position
Jul 4, 2010 at 3:47 PM
