2005 Chevy Trailblazer ABS light.
2005 CHEVROLET TRAILBLAZER
70,000 MILES • 6 CYL • 4WD • AUTOMATIC
NEWELLER2003
ABS and Brake light on on the dash. C0055 is the code. Warning lights are on all the time. Speedometer works fine. Swapped the 2 rear speed sensors from side to side. Read elsewhere that 4WD warning comes on instead. Ohmed out both speed sensors and 1.3K ohms. Could it be the ignition switch or the EBCM??
Apr 7, 2010 at 5:18 AM
HMAC300
  • 48,601 POSTS
It sounds like you may have a wheel speed sensor that is out. These videos will help us find the problem.
https://youtu.be/rTtAnsOlZU4
and
https://youtu.be/Pb6nXV-iamI
and
https://youtu.be/ANWVTh2RQoQ
Feb 27, 2021 at 5:36 AM
NEWELLER2003
Left rear wheel speed was out I got a new one all fixed
Feb 27, 2021 at 5:37 AM
