2005 Chevy Trailblazer 05 trailblazer diagnostic scanner wo
2005 CHEVROLET TRAILBLAZER
SLH852
Electrical problem
2005 Chevy Trailblazer 6 cyl Two Wheel Drive Automatic
Hello Ive got a 2005 Chevy trailblazer with and check engine light on and have a solus pro snap on scaner Ive connected to the obdII port and fond that pin 16 had no power so i plugged the cigarette liter power code and my went thru the vin step on the the scanner yet when it go to communicate it wont connect the key is on the on position. Ive even tried anther scanner and nothing so I know it not the scanner any hints.
Nov 27, 2009 at 3:43 AM
  • 110,244 POSTS
Check to make sure the wiring harness to the PCM is tight. Check pin 16 at the PCM to make sure it is making a good connection and is not corroded. Also, check continunity through that wire.
Nov 30, 2009 at 11:52 PM
