2005 Chevy Trailblazer
60,000 MILES • 6 CYL • 4WD • AUTOMATIC
GOMEZ321978
I have an 05 trailblazer. The 4x4 isnt working right. I've checked both actuators one on transfer case and other on pass. side axle also checked the fork and gears on that side. They all seem to be working fine. It has a bad vibration in front end. I checked wheel bearings and axles But that seems fine too. I tried to remove the housing but cant get it out threw holes without removing oil pan or engine. I'm lost can u help?
Mar 17, 2010 at 1:39 PM
RAZERBACK
  • 15 POSTS
you didnt say but have you checked the balance weights on tires rim or checked the tires to see if the belts shifted in the tire,i had one that did but i kept looking elsewhere hard lesson always check easy stuff first.
May 4, 2010 at 4:48 AM
