Water pump location for removal
TRACYT33
How do i remove the water pump on the vehicle listed above? I don't know where it is located....
It is a 2004 with a V6.
Feb 21, 2007 at 6:55 AM
CHEVY22
  • 1,375 POSTS
just want to clarify the engine size ????
Feb 22, 2007 at 10:50 AM
TRACYT33
it is a v-6 i believe a 4.3 liter.
Feb 22, 2007 at 1:04 PM
CHEVY22
  • 1,375 POSTS
okay, they are easy. you have to remove the fan shroud , 4 bolts two on each side halfway down the outside of the shroud , remove the belt , the fan which can come off in one piece don't worry about taking the fan off of the water pump pulley just remove the whole pulley , 4 bolts on the water pump and you are done.
Feb 22, 2007 at 1:22 PM
  • 110,248 POSTS
On this vehicle, it isn't too bad to replace the pump. It's located on the front of the engine. Here are the directions specific to your vehicle. The attached pictures correlate with the directions. Additionally, the torque specs are included in the directions.
_________________________
2004 Chevy Truck TrailBlazer 4WD L6-4.2L VIN S
Water Pump Replacement
Vehicle Engine, Cooling and Exhaust Engine Water Pump Service and Repair Removal and Replacement Water Pump Replacement
WATER PUMP REPLACEMENT
^ Tool Required
^ J 41240 Fan Clutch Wrench
Removal Procedure
pic 1
1. Drain the coolant.
2. Remove the fan and shroud.
3. Remove the drive belt.
4. Using the J 41240, secure the water pump pulley and remove the water pump pulley bolts.
5. Remove the J 41240.
6. Remove the water pump pulley.
pic 2
7. Loosen and remove the water pump bolts.
8. Remove the water pump.
9. Clean and inspect the water pump.
10. Discard and replace the gasket.
Installation Procedure
pic 3
1. Install a new water pump gasket.
Notice: Refer to Fastener Notice in Service Precautions.
2. Install the water pump and secure the water pump with the bolts.
^ Tighten
On the initial pass, tighten the bolts to 4 Nm (35 inch lbs.).
On the final pass, tighten the bolts to 10 Nm (89 inch lbs.).
pic 4
3. Install the water pump pulley.
4. Install the water pump pulley bolts.
5. Using the J 41240, secure the water pump pulley while tightening the water pump pulley bolts.
^ Tighten the bolts to 25 Nm (18 ft. lbs.).
6. Remove the J 41240.
7. Install the drive belt.
8. Install the fan and the shroud.
9. Fill the cooling system with the specified coolant and concentration.
10. Inspect for leaks.
Mar 25, 2020 at 4:44 PM
