transmission slipped completely in every gear
260,000 MILES • 6 CYL • 2WD • AUTOMATIC
MRJMARCO
What would make my transmission slipped completely in every gear when the engine is warm, but when its cold it runs fine?
Dec 21, 2009 at 1:16 PM
Good morning,
The first thing I would do is change the fluid and filter. The filter may be clogged not allowing proper flow for operation.
Look for any debris in the pan as that will also tell you if there is something going on internally.
Dec 7, 2021 at 12:56 AM
