2004 Chevy Trailblazer rotor
80,000 MILES • 6 CYL • 4WD • AUTOMATIC
BLAZERMAN04
I am having a problem loosening the bolts that hold the caliper. I am needing to remove it so that I can replace the rotor. I have tried wd-40. Please help.
Thanks.
Aug 21, 2009 at 7:22 AM
MERLIN2021
  • 17,250 POSTS
Threadlocking compound may be on the threads, use a torch, but be carful of rubber parts. heat the area of the mount the bolts go into, just enough to loosen the bolts, then cool with water. Or use a longer handle wrench...
Aug 21, 2009 at 7:30 AM
