We need to get the code it sounds like you have a hub bearing in the front that is out. These videos will help
https://youtu.be/Pb6nXV-iamI
and
https://youtu.be/ZgiPRG6jffc
try following this bulletin.Subject: ABS Red Brake SVC and 4WD Light On HVAC Blower Inoperative
Models: 2004-2007 Buick Rainier
2002-2008 Chevrolet Trailblazer models
2002-2008 GMC Envoy models
2002-2004 Oldsmobile Bravada
Diagnose for loss of battery voltage to the rear fuse block on circuit 300 ORN for the following fuses:
Note: Prior to proceeding forward with the information below, it is important to verify the voltage as indicated however it is equally important to verify the integrity of each circuit. This can be achieved by performing a voltage drop test or by adding a device to each circuit that will supply sufficient load to verify the circuits integrity.
HVAC 30A, 4WD 15A, HVAC 1 10A, BRAKE 10A, TBC RUN 3A.
Check circuit 300 ORN for battery voltage when the ignition key is in the RUN position.
Check for battery voltage at the rear fuse block under the rear seat Connector C1 pin D9.
If battery voltage IS NOT present at these locations, check for voltage at the ignition switch pin G for circuit 300 ORN.
If battery voltage IS present at the ignition switch pin G, check circuit 300 for an open.
If battery voltage IS NOT present at the ignition switch pin G, replace the ignition switch. please post back with the findings.
Feb 27, 2021 at 5:37 AM
