2004 Chevy Trailblazer Engine dont start
60,000 MILES • 6 CYL • 2WD • AUTOMATIC
KIMMERSUAQ
Hi there pls help!!!!
My Trailblazer will not start. My Chevolet Trail Blazer will not start, starter rotate well enough around. But it does not start the engine. I have tried to follow the below table no matter helps. All lights in the instrument plank goes out only once the engine service light. does anyone have an idea how I can get my motor running again ????
Quote - I Try this but it sosent succed.?????
Sometimes when battery voltage is lost, it may go into theft lock? Battery has a full charge and all connections are good? If you think it is the security system, you can try a relearn procedure, don't know if it will help?
Find out more about your Chevy Trailblazer Repair Question: NEED MORE TECHNICAL INFO? Car Repair Manual - Questions by Topic - First Things to Check - How to Car Repair - How Does it Work? - Donate Here
Nov 9, 2010 at 5:13 AM
KHLOW2008
  • 41,812 POSTS
Hi Kimmersuaq,
Thank you for the donation.
When engine can be cranked but does not fire up, you need to check/test what is missing, fuel or ignition.
Click the " First things To Check " link at bottom of post to get an idea what to look for.
Let me know what you find.
Was any repairs done prior to this occurring?
Did engine overheated?
Has vehicle been parked for extended periods?
Nov 10, 2010 at 2:26 AM
