Hi there pls help!!!!
My Trailblazer will not start. My Chevolet Trail Blazer will not start, starter rotate well enough around. But it does not start the engine. I have tried to follow the below table no matter helps. All lights in the instrument plank goes out only once the engine service light. does anyone have an idea how I can get my motor running again ????
Quote - I Try this but it sosent succed.?????
Sometimes when battery voltage is lost, it may go into theft lock? Battery has a full charge and all connections are good? If you think it is the security system, you can try a relearn procedure, don't know if it will help?
Find out more about your Chevy Trailblazer Repair Question: NEED MORE TECHNICAL INFO? Car Repair Manual - Questions by Topic - First Things to Check - How to Car Repair - How Does it Work? - Donate Here
Nov 9, 2010 at 5:13 AM
