2004 Chevy Trailblazer 4 Wheel Drive
GARYTATER
Drive Train Axles Bearings problem
2004 Chevy Trailblazer 6 cyl Four Wheel Drive Automatic 70K miles
My trailblazer will go into A4W and 4 Wheel Lo it will not shift into 4 wheel high. It goes into those two and shifts out of them just fine. Just no 4 wheel high. Any help will be appreciated.
Jan 30, 2010 at 7:28 AM
  • 75,988 POSTS
Hi GARYTATER, Welcome to 2carpros and TY for the donation
When you engage the 4W high do you hear the transfer case control module click and also a high pitch noise if not could be the front axle actuator or the TCCM-You need to have the TCCM scanned for code/s
Feb 1, 2010 at 11:16 AM
GARYTATER
[quote:4287075c75="GARYTATER"]Drive Train Axles Bearings problem
My trailblazer will go into A4W and 4 Wheel Lo it will not shift into 4 wheel high. It goes into those two and shifts out of them just fine. Just no 4 wheel high. Any help will be appreciated.[/quote:4287075c75]
It makes no noise when I shift into 4 high. I can hear it when it comes out of 4 low. Could it possible be the switch in the dash?
Feb 1, 2010 at 6:16 PM
GARYTATER
I hear no noise when I go to 4 wheel high, really don't hear a noise when I go to A4W or 4w lo. I can hear it come out of 4 wheel drive, but reallly don't hear it going in. Could it possible be a bad switch in the dash? I have used it a lot for 4 wheel high.
Feb 1, 2010 at 6:19 PM
  • 75,988 POSTS
Sir-try checking all wiring connectosr underneath that applies to the transfer case circuit, also check for loose connections on the transfer case control module and for corrosion on the pins.
If you got the dash lights and goes to 4H and you don't hear the TCCM clicks you have a bad relay in the module, if you hear the clicks could be the motor/actuator on the transfer that moves the gears in to the proper mode
Feb 1, 2010 at 7:31 PM
  • 75,988 POSTS
Thank you very much for your negative feedback.You have not done anything that I have suggested.This is not a simple fix,it requires extensive diagnostic to fine this problem,at this time request for your refund.
Feb 2, 2010 at 8:50 PM
GARYTATER
Do not want a refund. I have checked all you told me to that I could at this time due to deep snow here in Southwest Va.
Feb 3, 2010 at 2:27 AM
