2004-06 Chevy Trailblazer Electrical
BCOOVERT
I have two Trailblazers. The 2004 has 132000 miles, 90% of which is interstate miles. On this vehicle, in the last two months, I have lost fan speeds 1, 2 and 5 on the front fan control, the cruise control works intermittenly and the tachometer at times is off 2000 RPM, starting at 2000 instead of 0.
On the 2006 Trailblazer with 43000 miles, the gas guage changes constantly and never reads correctly, the radio cuts on and off and I have lost fan speed number 5. All of the problems just started this week.
Judging by the problems on these two vehicles, I am assuming that there may be some type of electrical issue causing all of this. Aside from two trips to the dealer and a day off of work, could you suggest a starting point to find the problems.
Thanks.
Brad
Sep 30, 2007 at 3:09 PM
DENNYP
  • 1,824 POSTS
[quote:16dddde722="bcoovert"]I have two Trailblazers. The 2004 has 132000 miles, 90% of which is interstate miles. On this vehicle, in the last two months, I have lost fan speeds 1, 2 and 5 on the front fan control, the cruise control works intermittenly and the tachometer at times is off 2000 RPM, starting at 2000 instead of 0.
Thanks.
Brad[/quote:16dddde722]the fan speed problems are probably caused from a bad blower resistor.fuel gauge problem could be a bad fuel level sensor or a faulty cluster.
Oct 1, 2007 at 12:18 AM
Suggested Repair
Check the blower motor resistor for the lost fan speeds. For the inaccurate fuel gauge, check the fuel level sensor and the instrument cluster.
Conversation Summary
The owner reported electrical issues on a 2004 Trailblazer, including lost front fan speeds 1, 2, and 5, intermittent cruise control, and a tachometer reading about 2000 RPM high, plus a 2006 Trailblazer with an erratic fuel gauge, a radio that cuts out, and lost fan speed 5. The expert said the fan problems are likely caused by a bad blower resistor, while the fuel gauge problem could be a bad fuel level sensor or a faulty cluster.
