Turn Key to reset the computer
2003 CHEVROLET TRAILBLAZER
MJDOWNARD
After replacing the steering column do you have to have a turn key to reset the computer?
Oct 28, 2010 at 10:52 AM
BLUELIGHTNIN6
  • 16,542 POSTS
computer shouldn't need reset after steering column replacement on this vehicle but if it has codes here is how you clear them
https://youtu.be/ahK_eucFi-k
Oct 29, 2010 at 12:59 PM
2CP-ARCHIVES
  • 4,540 POSTS
How do I reset the computer.
Apr 4, 2019 at 3:50 AM (Merged)
there is no re set. you can remove a battery cable but it wipes out a lot of needed info for driving
what is the issue??
BC4BARBIE
if we have service engine light and we do diagnostic. Machine said it was burning to rich. We had a bad exhaust manifold that my husband changed out himself. The car still runs like crap. Will this be corrected if we go somewhere and clear the codes on the computer? Is the car still trying to make up for the errors?
HMAC300
  • 48,601 POSTS
he could have left off a vacuum line but it still cold be the computer. You need a code scanner of some type to erase the code. the part he changed may not have fixed the car......
