2003 Chevy Trailblazer Stalling
83,000 MILES • 6 CYL • 2WD • AUTOMATIC
TOMN
Hello,I have a 2003 Chevy Trailblazer 2wd 4.2L...I start the car and turn the heater on ,the rpms go real low a few times then vehicle will stall out.It happens with vehicle in park or drive.If i don't use the heater i have no problem at all,it will not stall.I don't know where to begin to look,please provide me with a few pointers thanks for your help in this matter.Thanks,Tom
Dec 5, 2008 at 1:28 PM
BRIAN 1
  • 1,030 POSTS
Engine may stall with the air-conditioner on and or while adding additional loads to the engine at idle. An example of an addition load would be turning the steering wheel left or right with the air-conditioning on. This type of stall usually occurs during idle or slow parking lot maneuvers. This concern may not set any diagnostic trouble codes.
Recommendation/Instructions:
Clean the throttle body bore and the throttle valve plate using a clean shop towel with GM top engine cleaner, GM P/N 1052626 (Canadian P/N 993026) or AC-Delco Carburetor Tune-Up Conditioner, P/N X66-P, or an equivalent product.
post back if this fixes it.
Dec 5, 2008 at 1:42 PM
SPEEDYPETEY
Mine happens only when its raining or snowing. And the power cycles on the car. This indicates to me that it is a short somewhere. Meaning either wire or other electrical is getting wet. Check the electrical as an option. Connectors and circuit brakers.
If you already resolved it, let me know how. Thanks.
Dec 20, 2008 at 6:05 AM
