2003 Chevy Trailblazer Rack pinion/power steering
105,000 MILES • 6 CYL • 4WD • AUTOMATIC
AUDZCAR
How to determine if rack pinion versus power steering. When trying to turn need two hands just to turn the wheels. Turning the wheel is very tight.
Feb 11, 2010 at 1:33 AM
HMAC300
  • 48,601 POSTS
first check fluid level of power steering if it's down then look for the leak on one of the hoses. If not then take it to a pro who can check to see how much pressure the pump is putting out. That has to be tested first in order to determine whether it's a rack or not.
Feb 17, 2010 at 4:18 AM
