2003 Chevy Trailblazer New Battery going dead
65,000 MILES • 6 CYL • 4WD • AUTOMATIC
LISAME
What can I check on this Trailblazer?
Goes dead over night - something seems to be on and drawing battery down. Has there been any other problems like is?
Dec 2, 2009 at 5:52 AM
JDL
  • 16,098 POSTS
Welcome to the forum, I looked through some service bulletins, didn't notice anything particular. I'd look for lites left on, under the hood--interior-- luggage area, best time to check is in the dark. General info says battery draw no more than 30ma, that is no where close to half amp. If all else fails, check the amp draw, pull fuses one at a time, when the amp draw goes to normal, the problem circuit should be on the fuse circuit you just pulled.
I'd also have the charging circuit checked.
Dec 2, 2009 at 7:49 AM
