2003 Chevy Trailblazer LT 4.2L Vortec 40K miles 3.42 axle
J1DALOISE
Hi Guys,
I have some money to put into this vehicle for a few aftermarket performance upgrades. It's a great vehicle with no problems; just want to coax a little more from the DOHC L6:
Want to put a 3" cat-con off the exhaust manifold, as it appears no one makes a 6cyl. header for this application, then into a 3" muffler with dual 2 1/2" outlets & pipes the rest of the way. Don't know yet if there's a pre-cat or AIR on main cat. Have found both cat-con & muffler apps online from Flowmaster. Q: Will this eliminate too much back pressure? Does EGR need back pressure to function, like some older Fords? Do I even have EGR? If so, would 2 1/2" cat-con & muffler be more prudent to maintain some back pressure? Thanks for your advice. Joel
Oct 15, 2007 at 4:31 PM
2CARPRO JACK
  • 11,533 POSTS
A little backpressure will help it keep its low end torque, I wouldnt go much bigger than stock, but a little would definitly help it breathe
Oct 16, 2007 at 5:45 AM
