2003 Chevy Trailblazer Humming sound while deaccelerating f
55,000 MILES • 6 CYL • 4WD • AUTOMATIC
FUGISARNIA
I would like to know what the humming sound is when I slow down from 35 mph. I have already rotated my tires. There is some tread wear as they do have 55000 miles on them. When I rotated the tires there was no break pad wear. Would it be the rear differential or transmision humming? I am stumped because it only humms when slowing down at a slow speed. It is extremly hard to pin point a location inside the cab, sounds as if it is all over.
Apr 1, 2008 at 12:04 PM
DENNYP
  • 1,824 POSTS
could be tires. You will really need to pinpoint the noise location.
Apr 2, 2008 at 3:05 PM
FUGISARNIA
TY... I read another post on tires. What is feathering? My treads are getting quit small. The lowest tire is down to approx. 1/4" or possibly 3/16".
Apr 3, 2008 at 10:39 AM
DENNYP
  • 1,824 POSTS
Check Your Tire Inflation Proper tire inflation is essential for safe driving and long tire life. It's wise to check your tires' air pressure at least once a month with an accurate tire pressure gauge. Be sure to check pressure while your tires are cold and have not been used recently. Even driving a mile will cause your tire pressure to increase and give you an inaccurate reading. Should you experience continuous loss of inflation pressure, it could be an indication of a possible tire or wheel assembly problem. Consult your tire professional immediately if you encounter this situation. Check Your Tire Tread There are two popular ways to check for signs of tire tread wear. One easy way is the penny test. Simply insert a penny into your tire's tread groove with Lincoln's head upside down and facing you. If you can see all of Lincoln's head, it's time to replace your tires. Another way is to look at the tread wear indicator bar that's molded into your tires. The bars are located at the bottoms of the tread grooves in several locations around the tire. When a tire is so worn that these bars become visibly flush with the adjacent tread ribs, it's time to replace the tire. Goodyear suggests you check your tire tread using either method every 3,000 miles. Know What Certain Wear Patterns Mean As tires wear, sometimes wear patterns emerge that can indicate problems with your vehicle or tires. If you see any of these patterns, have your tires checked by a professional Goodyear Retailer. Here are some wear patterns to watch for. "¢ Wear on both edges: UNDERINFLATION Underinflation of a tire reduces its treadlife by increasing the tread wear on its outside edges, or shoulders. It also generates excessive heat which reduces tire toughness. Finally, it reduces fuel economy through increased rolling resistance because soft tires make your vehicle work harder. Abnormal tire wear may also be caused by misalignment or mechanical problems. "¢ Wear in center: OVERINFLATION When a tire is overinflated, the center of the tread bears most of the load and wears out faster than the outside edges. Uneven wear reduces the useful life of a tire. It could also be the result of misalignment or mechanical problems. "¢ Cups or dips in the tread: WORN PARTS Cupping (also called dipping) is most common on front tires, although rear tires can cup as well. It may be a sign that wheels are out of balance or that suspension or steering system parts are worn out. "¢ Sawtooth edges: MISALIGNMENT If the edges of your tire tread take on a sawtooth or feathered appearance, it's because of erratic scrubbing against the road. The solution is an alignment correction. Tire Balancing If your tires are unbalanced, you'll notice vibration. This can lead to driver fatigue, premature or irregular tire wear and unnecessary wear to your vehicle's suspension. Your tires should be balanced when they are mounted on wheels for the first time or when they are remounted after repair. Check your tire balance at the first sign of vibration or shimmy. Vehicle Alignment Your vehicle is properly aligned when all of its suspension and steering components are working smoothly and when its tire and wheel assemblies are running straight and true. If you notice uneven tread wear, it could be due to a misalignment and your vehicle should be serviced by a professional. Tire Rotation While many people are knowledgeable enough to rotate their own tires, the procedure is especially quick and easy for a professional. Your vehicle's owner's manual will specify the proper rotation pattern and schedule for your vehicle. If no specific schedule is indicated, a good rule of thumb is to rotate your tires every 6,000 to 8,000 miles. Tire Repair Tire repairs should be made by a trained tire professional. Proper repair procedure includes dismounting the tire from the wheel. This allows for thorough inspection of the tire for damage, as well as the use of a patch and plug to repair any punctures that fall within the guidelines for repair. Tire Buying Guide Download a pdf of the Goodyear Tire Buying Made Easy Guide. You will need Adobe Acrobat to view the pdf. The Goodyear Get thereâ„¢ Guide Fun-filled ideas for your next family road trip. Tire TipsDriving TipsTire SafetyReading A TireTire MaintenancePrepare Your Vehicle For WinterFAQsFind A Goodyear Retailer
https://images.2carpros.com/forum/automotive_pictures/102900_pennyTest_1.jpg
https://images.2carpros.com/forum/automotive_pictures/102900_under_1.gif
https://images.2carpros.com/forum/automotive_pictures/102900_over_1.gif
https://images.2carpros.com/forum/automotive_pictures/102900_cupping_1.gif
https://images.2carpros.com/forum/automotive_pictures/102900_onesidewear_1.gif
Apr 3, 2008 at 1:42 PM
FUGISARNIA
The noise seems to have stopped. It has been four days since I rotated the tires.
Apr 6, 2008 at 11:45 AM
