How do I replace the headlamp bulb (driver's side)?
Jan 21, 2010 at 4:19 AM
BLUELIGHTNIN6
✓Experienced Mechanic
On each side of the assembly, you will see a small, thin release bar that will pull up. Once both are in the "up" position, the entire assembly can be gently eased out.
Jan 23, 2010 at 2:25 PM
