2003 Chevy Trailblazer Brake Lights
72,000 MILES • 6 CYL • 4WD • AUTOMATIC
DAVID MACOR
I have a 2003 Chevy Trailblazer. My Top Brake lite works but the two below do not. I have replaced the light bulbs but still do not work, also check all fuses. What is my problem?
Thanks
Oct 26, 2008 at 1:28 AM
DENNYP
  • 1,824 POSTS
Check the sockets for the brake lights. They have problems with poor connections at the bulbs.
You will usually see the bulb has burn marks on it at the contact points.
Feb 27, 2021 at 4:34 AM
ERIC31
2002 has a recall for this problem. you may want to check on the03
