2003 Chevy Trailblazer ball joint replacement
68,000 MILES • V8 • 4WD • AUTOMATIC
BUGNI
had new tires put on car was told by tire shop that there was cupping of tires and i should have a front end alignment then was told that they couldn't align front end because all four ball joints needed to be replaced took car to another tire shop and was told no alignment was needed and ball joints were fine want some reassurance that car is safe if ball joints needed to be replaced would car be out of alignment?
Sep 12, 2008 at 4:37 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:401e8c17a9="bugni"]Suspension problem
2003 Chevy Trailblazer V8 Four Wheel Drive Automatic 68,000 miles
had new tires put on car was told by tire shop that there was cupping of tires and i should have a front end alignment then was told that they couldn't align front end because all four ball joints needed to be replaced took car to another tire shop and was told no alignment was needed and ball joints were fine want some reassurance that car is safe if ball joints needed to be replaced would car be out of alignment?[/quote:401e8c17a9]
Tire cupping is usually caused by weak or bad shocks or struts.
Ball Joint being bad would cause alignment problems.
Sep 12, 2008 at 4:41 PM
SILLIQUE
  • 7 POSTS
tire cupping is not usually caused by suspension. it is caused by the alignment being out. the second shop probably didnt unload the lower control arm. without doing this you cant check the ball joints. take it to a third shop for their opinion.
Sep 30, 2008 at 8:13 AM
