2003 Chevy Trailblazer Accelerator vibration
156,000 MILES • 6 CYL • 4WD • AUTOMATIC
TR0103
I have noticed after having the front differential replaced along with a front bearing that I have a vibration in the gas pedal. I notice this vibration while sitting in Park and pressing on the accelerator as well as when I put it in gear and accelerate. It is a constant vibration while pressing down on the pedal.
Feb 18, 2009 at 12:09 AM
RACEFAN966
  • 5,029 POSTS
Ok lets start with the simple and go from there ok. Are all the plug wires on good and tight? Are the plugs all in tight none are loose? Is the check engine light on? Have you check the spark plugs to see if any are bad? Are the O2 sensors all pluged in? Get back to me and we will go from there.
Feb 18, 2009 at 2:39 AM
TR0103
The check engine light is not on. I checked several plugs and they appear good. The O2 sensor was just replaced about 6 months ago and the wires appear intact. I have noticed one additional thing. The vibration in the accelerator pedal is only when it is below 2000 rpm. At any point the rpm's are above 2000 and I press on the pedal the vibration is gone. Is there anything that could have been moved or affected when they put in the new front differential?
Feb 24, 2009 at 3:02 PM
RACEFAN966
  • 5,029 POSTS
From what I can find no reason why the work done on the front diff should have caused any problems. Did you check to make sure no wires got pinched anywhere. If all looks good there maybe we can test the TPS if you have a digital multi meter. Let me know what you would like to do.
Feb 25, 2009 at 3:04 AM
KIBADER
My vibration started after I had a new radio and remote starter installed. Could something have happened during that installation to cause the vibration? I have a 2008 TB LT
Feb 11, 2012 at 12:16 PM
RIVERMIKERAT
  • 6,106 POSTS
kibader, there is a chance that the installers knocked wires loose from a sensor. Does the rpm sound or feel like it's varying? If so, check for vacuum leaks, check and clean the EGR and IAC valves.
Feb 12, 2012 at 12:46 PM
CHEVYFORLIFE
  • EXPERT
  • 33 POSTS
You can try and clean the throttle body out it could have some carbon build up causing a idle issues. Just use a rag and some throttle body cleaner and see if it gets better. And your cars doesn't have plus wires on it. It's s coil over plug system
Feb 12, 2012 at 3:11 PM
