2002 Chevy Trailblazer Transmission
95,000 MILES • 6 CYL • 4WD • AUTOMATIC
BPDPOSSE
A week ago after starting my trailblazer it was about 25 degrees outside. I pulled off and felt as if the transmission was slipping. After it warmed up it drove fine. Is it possible this could have been due to the cold or is this a sign of a future problem.
Dave.
Jan 28, 2008 at 1:08 PM
DENNYP
  • 1,824 POSTS
I would say your trans is showing wear if it's doing this at 25 degrees. It should not slip until you get down around below zero temps.
Jan 31, 2008 at 1:35 PM
