Electrical problem
2002 Chevy Trailblazer 6 cyl Two Wheel Drive 106 K miles
Is the tack hooked up to any kind of sencor in the transmission
Monday, February 16th, 2009 AT 7:30 PM
MASTERTECHTIM
MECHANIC
No, its connected to the ignition module
SPONSORED LINKS
Monday, February 16th, 2009 AT 7:32 PM
PUDGE68
MEMBER
It will work for a while then it will drop to 0 when I stop. If I cut it off and restart it it will work for a few min.
Monday, February 16th, 2009 AT 7:37 PM
MASTERTECHTIM
MECHANIC
That sounds like a tricky one. My money is on a faulty tachometer itself. How I would diagnose this is to use a scan tool and watch rpm and if it reaads correct when the tach reads zero I would suspect a bad tach
Monday, February 16th, 2009 AT 7:50 PM
PUDGE68
MEMBER
I just change transmission filter and fluid iin it and after that is when it started this that is why I was woundering if this could have caused the problem
Thanks
Monday, February 16th, 2009 AT 8:00 PM
MASTERTECHTIM
MECHANIC
No, not a chance. Double check the wiring by the transmission dipstick tube because thats near the ignition wiring harness to make sure there is nothing touching.
