2002 Chevy Trailblazer ront end whell noise
95,000 MILES • 6 CYL • 4WD • AUTOMATIC
HACKPEANUT
I am getting a rubbing noise in my front passenger side wheel that sounds like a rubbing noise only when the vehicle is rolling.There is nothing visible in the wheel well rubbing against the tire which is what it sounds like.
Mar 15, 2010 at 8:56 AM
HMAC300
  • 48,601 POSTS
it may be the brakes squealer. If it goes away when you press the brakes thatn get your brakes checked. If not it can be a wheel bearing going bad. Take it to a pro and he can check it to see if its' any good.
Mar 16, 2010 at 12:57 PM
