2002 Chevy Trailblazer Right Passenger Door is out
67,678 MILES • 6 CYL • 2WD • AUTOMATIC
CHEVYMANNN8
IN my trailblazer the passenger door will not lock or unlock; the window doen't open or can you set the mirror automaticly all on the passenger door. The thing is once in a while it will work for a second or two. Dealers are charging high money for a electral wire test but i think there is a better altnative.
Nov 5, 2009 at 10:41 AM
STEVEW84
  • 673 POSTS
Sounds like a passenger door module. Door modules go out all the time on Trailblazers, envoys, etc. Sometimes a door module from the junkyard will work. If you get one from the dealer then the dealer has to reprogram it. HTH.
Nov 7, 2009 at 1:10 AM
