Electrical problem
2002 Chevy Trailblazer 6 cyl Two Wheel Drive Automatic
Have a 2002 Chevy Trailblazer and have replaced the Alternator and the battery recently. Also changed the battery cables. Truck drives fine most of the time, and then it is like you hit a bump in the road, and the battery starts to drain. You re-charge the battery and it won't keep the charge, until maybe one strange day, it does and you don't have a problem until you hit that pesky bump in the road again. The trouble continues to happen and it will leave me stranded anytime. I don't know what to do or what to check. Help if you have a step by step process to eliminate the culprits!
Jul 16, 2010 at 12:25 PM
