2002 Chevy Trailblazer POWER WINDOWS AND DOOR LOCKS
61,000 MILES • 6 CYL • 2WD • AUTOMATIC
PETER APPELBAUM
THE POWER WINDOW AND DOOR LOCK ON THE PASSENGER SIDE DOOR STOPPED WORKING AT THE SAME TIME. IS THIS A THERMO FUSE AND IF SO WERE WOULD IT BE LOCATED. IF NOT ANY IDEA AT WERE TO START LOOKING TO DIAGNOSE.
Dec 15, 2007 at 10:46 PM
DENNYP
  • 1,824 POSTS
sounds like the passenger door module went out. You will need a tech2 scanner to check communications with the module.I recommend having it checked out at your local dealership.
Dec 16, 2007 at 5:27 AM
