2002 Chevy Trailblazer p1345 code
CPATON
Computer problem
2002 Chevy Trailblazer 6 cyl Four Wheel Drive Automatic
i went through a large water puddle and then the engine light came on. it started running real rough so took it to autozone to have the code read. p1345 came up. i know where the camshaft position sensor is but cannot find where the crankshaft positioning sensor is.
if you could please help with this i could save lots of money as i am unemployed at the time.
thank you,
craig
Oct 24, 2009 at 5:34 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the crankshaft position (CKP) sensor is located on the left rear of engine block, below the starter.
Oct 24, 2009 at 7:01 AM
CPATON
thank you so much for your speedy reply. this helps out alot.
Craig
Oct 24, 2009 at 7:33 AM
