2002 Chevy Trailblazer GASOLINE SMELL
120,000 MILES • 6 CYL • 4WD • AUTOMATIC
PICKUPCHUCK
THERE IS VERY SLITE GASOLINE SMELL ON LEFT SIDE SOMEWHERE. HERE ALMOST DO NOT SMELL IT HOWEVER, AGAIN YOU DO. SHOULD I DO THE FOLOWING:
1. CHECK FOR SLITELY BROKEN GAS LINE?
CKECK GASOLINE FILTER LEAKING AT CONNECTIONS?
OR IS THERE SOMETHING ELSE I SHOLD BE LOOKEN AT? THANK YOU VERY MUCH....CHUCK
Oct 18, 2010 at 7:09 AM
JDL
  • 16,098 POSTS
I'd check gas cap-- fuel lines under the vehicle and under the hood-- evap system may let fumes escape, check fuel pressure regulator vacuum line, where applicable, for gas. Use a fuel pressure gage, see how fast pressure leaks down, with everything off?
Oct 18, 2010 at 8:22 AM
