2002 Chevy Trailblazer check engine light
51,390 MILES • 6 CYL • 4WD • AUTOMATIC
BULLCRAB
  • 6 POSTS
rough idle when leaving a light cleared code for cyclinder missfire(5) did the plugs,coil,f filtercode still come's back after all is checked again
Jan 26, 2008 at 10:32 AM
BULLCRAB
  • 6 POSTS
bump
Jan 29, 2008 at 4:51 AM
DENNYP
  • 1,824 POSTS
check th cylinder 5 injector connector for a poor connection.
Jan 31, 2008 at 1:32 PM
BULLCRAB
  • 6 POSTS
Found out that the trailblazer has a leak in some of there molding on back edge of hood causing, coils to get wet in bad weather, mine got wet and brought up misfire on cyclinder 5 change coil check light came back on, coil was bad it was brand new(how i know they swicthed coil on 5 to 6 had misfire moved to 6 )( the water can get in just above cyclinder 5) edge mold P/n25788476 this happens on models 2002-2007
Jan 31, 2008 at 1:49 PM
